2021 Fox 36 Performance from my 2021 Megatower that I upgraded with a damper, air shaft, and bleeder valves. Fork is less than 6 months old, 170mm air shaft and 2022 Grip 2 VVC damper has 10 rides on it tops. Fork has cosmetic wear on CSU from cable rub, otherwise it's fine. Steerer is cut to 7 1/8'', see photos to see how much wiggle room there is with a stem attached. Comes with stock 160mm air shaft, Grip damper, and a star nut to install when you get it (I used a OneUp Threadless Carrier so no star nut installed). Fork is definitely solid... only selling because I have a 2022 Fox 38 that I wanted to give a try. UNITED STATES ONLY... $850+shipping. DM if interested.
