Any insight? Leaks? Date?
Brain? please noooooo:nono:
There will not be a brain on the 2021 Evo...Any insight? Leaks? Date?
There are reports coming out of LBS manager seeming to confirm that the 2021 Epic Evo will be Brainless and 120 front and rear. They believe that the Stumpy ST will be no longer available as the Epic will fill that niche. I wonder what the length and stroke on the shock will be because I don't believe there are many options for the current model Epic.There will not be a brain on the 2021 Evo...
It’s a new model so it doesn’t matter what the current one is. It’s designed around a 120There are reports coming out of LBS manager seeming to confirm that the 2021 Epic Evo will be Brainless and 120 front and rear. They believe that the Stumpy ST will be no longer available as the Epic will fill that niche. I wonder what the length and stroke on the shock will be because I don't believe there are many options for the current model Epic.
My point is the current shock length/stroke is an oddball size so you don't find many aftermarket or high performance replacement/upgrade shocks. I hope they don't do that again, but I believe it may be part of having two water bottle cages in the front triangle. Also, there is no such thing as 120 shock ...the 120mm refers to the wheel travel not the shock length or stroke, so saying it is design around a 120 is sort of confusing.It’s a new model so it doesn’t matter what the current one is. It’s designed around a 120
for the EVO.
Any other geo numbers? CS?66.5 ht
Hi the TT length is not important an more with the seatpost and headtube angles changing so much.Thanks
Is this from Europe, Asia or Down Under pages? Or USA?
XL seems small and how is it they leave out TT length?
I got a call from my shop yesterday that my EVO Expert would be ready very soon. /QUOTE]
I also have an Evo Expert on order, but it's Aug. 9 and still no word on a possible arrival date.
