1 - 6 of 6 Posts
· Registered
Hey all, I have an XL Chisel 2021 model frame on order, should be arriving soon. Have almost all parts for my build, expect my front fork. Will be going with a 100mm Rockshox SID or Reba. Most likely a pull-off from another bike.
Here is the question. Does anyone know the steerer tube length that comes on the bike from the factory build? ie. Will a tube cut to 6.5 fit? I run my Thomson stem low, maybe 1 spacer, FSA headset.
Thx so much. (Called Specialized, but they are overloaded with calls).
· Registered
I had an XL 2021 chisel that I put a take off Fox 32 on. And my steer was 7 1/4". I had 20 mm of spacers under the stem and none on top.. 6.5" may be cutting it close :unsure:
· Registered
Headtube Length + Headset Stack Height + Intended Spacer Stack Height + Stem Steerer Clamp Height = Minimum Steerer Length
If the sum of all parts is < 6.5in you are fine.
All those dimensions are readily available from manufacturers website, or through self measuring with a calliper.
· Registered
Depend. If a carbon steer. Is recomended to have a spacer on top , if not. Metal steering tube not need spacer on top
1 - 6 of 6 Posts
