Hello. Neubee here.
What's is the most fork travel/upgrade that I can put on 2020 Trek Top Fuel 8 XL going from Rockshock silver 120mm that is a stock fork. I regularly bottom out although pressure is by spec and there is nothing wrong with it otherwise.
I am 250lbs and was told any increase in travel will change geometry significantly and put a lot of pressure on steer tube causing it to crack.
Some places are mentioning it is safe to go 140mm...no idea, Trek website has no documentation on it.
I appreciate any insights.
