What is the spec for the 9.7?
And other models if you know?
Sent from my SM-G930F using Tapatalk
Frame- OCLV Mountain Carbon main frame & stays, tapered head tube, Knock Block, Control Freak internal routing, Carbon Armor, magnesium rocker link, Mino Link, ABP, Boost148, 115mm travel
Front suspension- RockShox Reba RL, Solo Air spring, Motion Control damper, TwistLoc remote, tapered steerer, 46mm offset, Boost110, 15mm Maxle Stealth, 120mm travel
Rear suspension- Fox Performance Float, 2-postion DPS damper, TwistLoc remote, tuned by Trek Suspension Lab, 190x45mm
Wheels
Wheels- Bontrager Kovee Comp 23, Tubeless Ready, 6-bolt, Boost110 front, Boost148 rear
Tires- Bontrager XR3 Team Issue, Tubeless Ready, Inner Strength sidewall, aramid bead, 120tpi, 29x2.40"
Drivetrain:
Shifter -SRAM NX Eagle, 12 speed
Rear derailleur- SRAM NX Eagle
Crank- SRAM NX Eagle, DUB, 32T steel ring, Boost
Bottom bracket- SRAM DUB, 92mm, PressFit
Cassette- SRAM PG-1230 Eagle, 11-50, 12 speed
Chain- SRAM NX Eagle, 12 speed
Components:
Saddle- Bontrager Montrose Comp, steel rails
Seatpost- Bontrager Line Dropper, 150mm travel, internal routing, 31.6mm
Handlebar- Bontrager Comp, alloy, 31.8mm, 15mm rise
Stem- Bontrager Rhythm Comp, Knock Block, 31.8mm, 0 degree
Headset- Knock Block Integrated, cartridge bearing, 1-1/8" top, 1.5" bottom
Brakeset- Shimano hydraulic disc, MT501 lever, MT500 caliper
