I'm in the market for a new bike and want to know how the new Switchblade rides. Any owners out there?
Sent from my SM-G950U using Tapatalk
I ride around freezing temperatures over here and never had issue with the Fox Transfer. Especially if it's new. Usually they will need a service after 1 1/2 years or so to run smooth again.Only issue is that I've come to the conclusion that Fox Transfer posts don't like cold weather. It was sticky going up in the morning but improved as it warmed up outside.
I previously owned a 2018 Mach 429 Trail, and have demoed the Trail 429 a few times as well. I now own the 2020 Switchblade, and continue to be blown away by this bike. The pedaling efficiency when you are putting the power down is insanely good. I am regularly getting PRs on technical trails I've ridden many times with this bike, and not just descents. The suspension feels plusher and on a parking lot ride makes you think the bike will be less efficient on the trail, but I can assure you that is not the case. The DPX2 tune is amazing - plush and yet supportive. The middle position is great for a slightly poppier/firmer feel while retaining small bump compliance, and the open mode is amazing for technical stuff.I know its not really apples to apples but can anyone compare the climbing efficiency of the Trail 429 to the new SB. Really had my sights on the Trail 429, demoed one last year, really liked it, solid pedaling platform. Great for my midwest area.
But this new SB has really piqued my interest. Really like the the looks of the updated geo, and new shock tune. The engineering and tech is getting so good. Wondering if this can be my one "do it all" bike? Because as of now a hardtail is my one "do it all" bike. Hope to find a demo in the near future.
Thanks for the detailed response. You mentioned a lot of things that really stood out to me. Like the efficiency when putting power down. Although i'm not a racer, I don't consider myself a casual trail rider either. I do like some speed and maybe a little air under the wheels. Also your familiarity with Pivot/DW suspension gives me a good reference the SB's efficiency.I previously owned a 2018 Mach 429 Trail, and have demoed the Trail 429 a few times as well. I now own the 2020 Switchblade, and continue to be blown away by this bike. The pedaling efficiency when you are putting the power down is insanely good. I am regularly getting PRs on technical trails I've ridden many times with this bike, and not just descents. The suspension feels plusher and on a parking lot ride makes you think the bike will be less efficient on the trail, but I can assure you that is not the case. The DPX2 tune is amazing - plush and yet supportive. The middle position is great for a slightly poppier/firmer feel while retaining small bump compliance, and the open mode is amazing for technical stuff.
I also have the Mach 4 SL as an XC race bike, so personally, if I could only have one MTB, it would still be the Trail 429. But if you already have a hardtail for smoother rides/races, I would not hesitate to get the new SB. It's that good.
One more note - I'm riding in the HIGH flip chip position for techy New England trails, which really increases the versatility of this bike. I'd throw it to LOW for trips to the bike park or a trip out West.
Good response!I previously owned a 2018 Mach 429 Trail, and have demoed the Trail 429 a few times as well. I now own the 2020 Switchblade, and continue to be blown away by this bike. The pedaling efficiency when you are putting the power down is insanely good. I am regularly getting PRs on technical trails I've ridden many times with this bike, and not just descents. The suspension feels plusher and on a parking lot ride makes you think the bike will be less efficient on the trail, but I can assure you that is not the case. The DPX2 tune is amazing - plush and yet supportive. The middle position is great for a slightly poppier/firmer feel while retaining small bump compliance, and the open mode is amazing for technical stuff.
Yeah I think it's definitely easy these days to purchase a bike that goes too far in terms of "modern" geometry for riding in certain areas with slower, up/down technical trails. The Switchblade (at least in the HIGH position) is really really good in this stuff - better than I thought it would be. The steep(ish) seat angle helps you grind up the steep climbs - in fact, I have regularly been making it up tough climbs that my brain says "nope"... just keep pedaling and the bike finds traction out of nowhere and keeps going. One of the major differences I find between it and the Trail 429 is that the rear suspension has a notably plusher feel (makes sense with about an inch more rear travel). The Trail 429 to me feels like a solid, beefed-up, capable XC bike in how it rides - it encourages you to stand up and sprint and the platform is incredible. The SB "feels" softer, and on a gradual climb may not encourage standing and hammering (partly due to the 160mm fork), but in reality it is not slower, at least on anything remotely technical. Also, I've found that the third (firmest) position of the DPX2 still has enough compliance that you can use it in this setting for hammering on a smoother trail if you want. Much more usable than the third position on a DPS, for example, which is fully locked out and only useful on road or gravel.Thanks for the detailed response. You mentioned a lot of things that really stood out to me. Like the efficiency when putting power down. Although i'm not a racer, I don't consider myself a casual trail rider either. I do like some speed and maybe a little air under the wheels. Also your familiarity with Pivot/DW suspension gives me a good reference the SB's efficiency.
I feel the geo is a good fit for my riding trails, probably similar to yours... rocky, rooty, tighter areas, shorter ups and downs. Its a modern, progressive geo but not extreme. So easy to get caught up in the long, low, super slack, super steep trend. I'm sure it is beneficial to certain areas, just don't think it would be for me. Super excited to get out on a demo.
Thanks again for your insight.
Cheers
Watched a Youtube video of the Loam Wolf interviewing Chris Cocalis talking about the new Switchblade. Maybe you've seen it? Anyway he talks about working with Fox to revamp the Dpx2 shock specifically for the switchblade. Listening to him explain it supports what you're saying about it. Good stuffI never took the SB off the open position when I rented and it just stuck to the trail when climbing. My 5.5 is much the same. The platform of this particular iteration of the dw link is just phenomenal IMO. I am just so impressed with how these Pivots climb. I am regularly cleaning stuff I could never make it up before (now it's about finding the right gear) I pretty much know the bike will climb it if I do my part.
I had a standard DPX2 on my Mach 429 Trail, and liked it, but I agree the hard work that Chris did with Fox on the Switchblade-specific DPX2 design paid off.Watched a Youtube video of the Loam Wolf interviewing Chris Cocalis talking about the new Switchblade. Maybe you've seen it? Anyway he talks about working with Fox to revamp the Dpx2 shock specifically for the switchblade. Listening to him explain it supports what you're saying about it. Good stuff
https://www.youtube.com/watch?v=flIj2aOKdnE
Yeah, that's sound advice. You've provided some good input about the Switchblade. It's been about a year since demoing the 429. It would be good to demo both closer together for a better comparison. Unfortunately the state lock down due to this pandemic is slowing the process. But as long as we can all get through this with our health, that's all that really matters. And at least the trails are still open!!Makpak - don't mean to talk you out of the Trail 429, as it really is an amazing bike. I'd say demo both on the same trails if you can and make your choice based on which fits your style and needs the best. They have similarities, but different feels for sure.
This is an astute observation.The shock tune is very very progressive. I set sag correctly yet I could not use anywhere near full travel even on sizeable drops. I would be taking volume spacers out I think.
Hi John,This is an astute observation.
We ship the bike stock with a 0.6 volume spacer in the air can, because we knew a lot of people would be using this bike not just for trail riding, but also for enduro racing; and we wanted to make sure the shock would offer enough support for that.
If it's mostly a trail bike for you (as mine is for me), you can swap that out for a 0.4, a 0.2 or no spacer at all. I tried mine a few different ways and found that a 0.4 was my sweet spot.
Spacers are pretty cheap and easy to install, so I encourage everyone to do some tinkering!
JP
I've got about four hours of riding on the new switchblade, the xt build. I rented a demo at the LBS.I'm in the market for a new bike and want to know how the new Switchblade rides. Any owners out there?
