A couple questions about the new Primer 2020:
Does anyone know how large of a rear tire the S version can handle in 27.5? Can it be used as a true 27.5+ bike for winter use with 3.0-tires?
The original drafts for the Primer from about a year ago showed an ACV version with wider rear end than the 29er. Are the rear ends of the Primer S and Primer 29 now the same?
Is the tire clearance on the Primer 29 better than the old Primer? I am running 29x2.6 on my old Primer, but with very little tire clearance. Was hoping for space for a 29x2.8 winter tire as well.
Complete bikes come with 170mm cranks. Will it work ok with 175mm in high BB setting?
