I have not owned a Sid, normally all you have to do is replace the 120mm airspring with the correct 100mm airspring. The airsprings are sold as a complete separate part.
Thanks. That's for a 120 to 100mm swap?I have not owned a Sid, normally all you have to do is replace the 120mm airspring with the correct 100mm airspring. The airsprings are sold as a complete separate part.
Yep you just swap the airspring.
Here is the service manual for the 2020 Sid. It's a great resource and shows you how it's done.
https://servicearchive.sram.com/sites/default/files/techdocs/gen.0000000005978_rev_a_2020_sid.pdf
On page 19 it goes over the airspring service and addresses travel adjustment.
If you have a few skills and tools you can do it yourself.
As you are in the USA, one of the best places to find new and used mtb parts is the Pinkbike Forums.Thank you. That's great. I'm not on the hunt for a 120mm SID/Reba from 2020-2021, and a 100mm air spring. eBay time.
Thanks.
