Would you mind sharing what exactly was the causing the blow up problem with the Topaz 2. What did they do to try to fix it each time under warranty?
Sorry, I did not get exact details as I took it to my LBS and they shipped it off as it was under warranty without looking into it themselves.
To give you an idea - first time around there was this sudden grind/friction in the shock and the open/mid/firm settings stopped working. Shipped off and on return LBS said something about shaft replacement and rebuild so off I went again.
About 6 rides later suddenly felt real soft and there was oil all over the place. Sent away again - was advised it was rebuilt and new seals put in. another 5-6 rides and exactly the same happened. Sent away and once again and same answer. Then another 5 rides or so and oil seemed to start coming from around the rebound knob. Was riding along flat singletrack, no rocks/drops/jumps, just nice and flowy and suddenly felt like I was really sliding around a bit - as it turns out it was the shock that gave up again...
That's when LBS contacted Giant. No questions asked from them and will replace with shock of my choice.
it's a pity as the DVO Sapphire on the front is absolutely amazing.
