1 - 1 of 1 Posts
Located in Denver, Colorado metro. Frame size is Large.
Selling my beautiful Stumpjumper as I only care to have one bike in my stable at this point in time. This bike is the "Expert" edition, and notable upgrades I made during the past 2 years are the Fox 34 Factory fork, Fox Float DPS shock, SRAM Guide RSC brakes, and RockShox Reverb Dropper post (5 rides with this post). The bike has the usual scratches on the frame and rims that a mountain bike would take, but there are no significant gashes.
Fork: FOX 34 Float Factory, 130 mm
Shock: FOX Float DPS, 120 mm
Rear Derailleur: SRAM GX Eagle, 12-speed
Shifters: SRAM GX Eagle, trigger, 12-speed
Crankset: Truvativ Descendant, aluminum, Boost™ 148, 170mm crankarm, 24mm spindle
Cassette: SRAM GX Eagle, 12-speed, 10-50t
Chain: SRAM GX Eagle, 12-speed w/ PowerLock®
Bottom Bracket: SRAM GXP
Brakes: SRAM Guide RSC
Handlebars: Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
Stem: Specialized Trail, forged alloy, 4-bolt, 5mm rise, 40mm
Grips: Specialized Sip grip, half-waffle
Front Hub: Specialized, sealed cartridge bearings, 15x110mm spacing, 28h
Rear Hub: Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
Rims: Roval Traverse Carbon 29, hookless carbon, 30mm inner width, 28h, tubeless ready, hand-built
Spokes: DT Swiss Industry
Seatpost: RockShox Reverb Stealth, 170 mm
Saddle: Body Geometry Phenom Comp, Adaptive Edge design, hollow Cr-Mo rails, 143mm
1 - 1 of 1 Posts
