So a couple weeks ago I posted here asking about stiction/problems like the fork resting with almost 20% sag with this BRAND NEW fork. All kinds of things were recommended. Some commented that RS are notorious for being shipped from the factory low on leg oil so be sure to check that first. So I ended up servicing the lowers and replacing the dust wiper/seals with low friction pieces from Push. When I broke it down, plenty of oil ran out so that didn't seem to be an issue. The foam rings were dry as a bone though I suspect this is going to be the case 99 out of 100 times when you pull the lowers off even when the fork is functioning properly. Nevertheless, I put everything back together...problem still there. No better, no worse.
So like I should have done in the first place lol, I took it to the local SRAM dealer. Rolled the bike inside. Grabbed their bike mechanic. Showed him. And he's immediately like yep, it's messed up....from the factory. He says more than likely it is the Motion Control damper malfunctioning. He said it seems to be a common issue. He goes on to say that one of the other bike mechanics there has a brand new Kona Process with a 160mm Lyrik on it that is doing the same thing. Real nice SRAM. That's great! Not.
Ok...my question is WHAT THE F is going on with SRAM/RS??? How is this possible in this day and age of technology and quality assurance?? Not to mention that with this being such a common issue, how is this not fixed once and for all?!? Maybe a bad run here and there or a technical issue possibly with an older design. But come on, this is an old design and anything that is problematic with it should have been addressed and fixed YEARS ago. So now I get to spend the rest of the summer riding my brand new bike on a defective RS fork. He said sure, bring this thing in when you are done riding and we'll send'er off and they will warranty, no prob. Yeah, alot of good that does me right now in the middle of riding season.
Bottom line, RS should be ashamed of such piss poor quality. It is unacceptable and that is being generous. With any luck, a SRAM employee will see this and shed some light on the subject. This is wrong on so many levels.
Anyone else have a similar experience?
