I recently purchased a 2019 Specialized Epic Pro, which comes with the Rock Shox SID Brain fork. This is the Brain model that includes the top adjustment for the Brain, which is the same as the fork that comes on the S-Works models (w/ the Debonair air spring).
I have been having some challenges getting the fork setup. I should probably preface this with the fact that I weigh approximately 135lbs. ready-to-ride. I would consider myself more of an XC-race type of rider vs. someone who is out hitting a bunch of jumps. That being said, I do consider that I ride the bike aggressively.
My issue is that after riding the bike at the local trail system, I am rarely using more than 3/4 of the travel of the fork. Although the Rock Shox air guide indicates I should need between 70-90psi in the fork, I have gone as low as 58psi w/ the Brain set to the least effective setting (we will say 1/6). Even with that setting, I am getting about 3/4 travel. I feel like the local trail has enough drops and rough sections that I should be getting full travel. Currently the fork has zero tokens in it.
I am curious if anyone has experience or suggestions for a lighter rider with this fork. Do I need to look at a different oil weight in the fork lowers? Should I consider something else? It just seems like if I have to go to 50-55psi to get the fork to use full travel, there is something I am missing.
Edit: I deflated the fork, and by measurement can only get 90mm of travel out of the fork. There seems to be something internally limiting travel.
Thanks in advance!
-Brian
Thanks in advance!
-Brian
