1 - 8 of 8 Posts
· biking is fun
Demo'd a few bikes and settled on the Ripmo... When I rode it the bike had a DPX2 on it which seemed to work well.
Any thoughts on the X2? I have looked a bit through the other threads and it looks like the X2 may be a bit more popular, especially the 2019 ones. I am getting a Works angle headset (-1 degree), a factory grip2 36, and I ride pretty aggressive. I'll hit up to 8 foot drops and 15ish foot gaps... Bigger if they are tables.
The only downside to the X2 is I'm a set and forget kind of guy. I don't like fiddling with my suspension. I check tire pressure by feel even.
· Registered
· Ride Fast Take Chances :)
I would not recommend a coil. The frame is not designed with enough progression to run one.
2019 X2 is an excellent shock as is the DPX2. If you are going to be going big and riding high speed tech trails, I would go with the X2. Once you get it dialed, you should not have to change it. I check pressure and occasional run the shock wiz just to verify the shock doesn't need service.
Find the sweet spot and leave it there, unless you are racing or significantly changing riding style/terrain.
· Registered
Yea, this Im aware of. Thats why I got curios, why then would they make a specific one with coil. What news could be inside.
I am racing although not on high level. Im always having a spare shock so I don't get any downtime during the season, and usually try too widen my experience. Running the dpx2 now and was looking for a super deluxe on air when I came across this.
1 - 8 of 8 Posts
