1 - 7 of 7 Posts
Hey all,
I have a 2019 Krampus complete on order. It comes with Novatec hubs (non-XD), Sunrace 11-42 11spd cassette, and NX crank & rear derailleur.
I am going to upgrade to the GX Eagle drivetrain (well, X01 rear derailleur, but GX for the rest) since I have most of the components already.
Questions:
1. Anyone know what model Novatec hub is on the rear? I assume I have to get a Novatec-made XD driver to replace whatever driver comes with the bike. Novatec's web site makes it clear that their XD drivers are matched to specific models of their hubs, which makes sense. Surly doesn't mention the model #.
2. Anything special with the chainline I need to be aware of on the Krampus, other than Boost? I assume the DUB BB (73mm BSA) + DUB GX Eagle crankset should line up with the GX Eagle Cassette OK - is that true?
Thanks for any help. I was trying to buy something tonight online since a lot of places are extending their Memorial Day sales through midnight. Longshot, I know. Otherwise I'd just call the LBS I bought the bike from...
Tom
Wanna ride bikes?
Everything else will be compatible and align properly, but you need to figure out the correct XD freehub for that hub. If there isn't a PN stamped on the hub shell for reference you may need to ask Surly directly (through your LBS).
Discussion Starter · #3 ·
Thanks, OneSpeed - was hoping the hub/driver was the only issue. LBS should call me back today to confirm which XD is needed for the Novatec hub on the Krampus.
Discussion Starter · #5 ·
https://www.ebay.com/itm/SRAM-GX-Ea...tte-Derailleur-Trigger-Chain-Kit/223496621826
Just get this. I've done this to a whole bunch of bikes including a first gen Krampus and a new one. Works fantastic.
I actually have that very kit from ebay, but for some reason I cannot recall, I thought that the driver on the 2019 Krampus' rear Novatec hub is not a 'standard' driver? If it is, I'm all set! LBS hasn't called back yet to verify...
turtles make me hot
I can't imagine what else it would be. It'll mount up fine. That bike comes with an 11 speed Sunrace cassette.
1 - 7 of 7 Posts
