I'll try to provide as much critical information as I can.
This is the stock fork on a 2019 Giant Trance 29-2, a Fox 34 Rhythm, 130 travel, Boost, 44 offset. It has one volume spacer installed, roughly 85 psi to run at 20% travel (I'm 190 in gear).
Pretty basic damper, so I run a little bit of compression damping on the dial (no detents on this fork, so roughly 20-25% of the dial) and 4 clicks of rebound damping.
Overall performance is OK, but I'm getting a really frustrating noise that I can't diagnose. My best description is a "thwack" sound, that's in tune with the fork movement (i.e., it moves in time with the fork moving through it's travel). It's not a metallic sound, almost sounds like plastic.
It sounds very much like a topout clunk, but I can't reproduce the sound in the normal way (pulling up into a manual, pedal wheelie off curb, etc.). Nor can I reproduce the sound by hitting the fork with my hand, twisting, picking up the front and dropping, or by just running into a curb.
The noise consistently appears at higher speeds and in tune with hitting square edges (of which, we have thousands here in Phoenix). So, I generally don't hear the noise while climbing.
The faster I'm going, the faster the thwacking sound. It does appear to get worse the hotter the fork gets. Small changes in compression or rebound do not make a difference as far as the sound is concerned.
I took it to my favorite LBS with mechanics I fully trust. They obviously couldn't reproduce the sound since it only appears at speed. The took the fork apart and didn't find anything amiss, damaged or obviously wrong.
Put it back together, I rode it down National Trail at South Mountain this morning. No change.
I understand that sound can migrate, but I can almost feel the thwacking in the bars and you can hear it's in time with the fork moving.
Sorry for the long read. Anyone have insight or heard anything like this? Thank you.
