1 - 7 of 7 Posts
Hi guys, I’m a soon to be owner of a 2019 Enduro. I noticed that Specialized went with only 2 holes for the ISCG05 tab. I would like to install a bashguard, but am unsure if there’s any bashguide (bashguard + chainguide combo) that would be able to fit with just the 2 holes without stressing the frame.
I’m worried that the bashguides in the market that were designed to be mounted on the standard 3 hole tabs might not hold up as well on the 2 hole tabs on my frame.
Does anyone have any idea?
Discussion Starter · #3 ·
I just run a normal bashguard and chainguide and dont worry that its only held on by two bolts...
Thanks for your reply oikeith, that is a bit reassuring but I'm also concerned that it may void the frame warranty - did your specialized dealer/lbs have anything to say about that?
No Clue Crew
How would it void the warranty? It's how Spec. built the frame. You really only need two ISCG bolt tabs. Run whatever bash you like.
Its only a bashguard held on my 2 bolts, at worst the bolts will strip, I dont see anything else untowards which could happen. After having several collisions I dont see how this could really happen. You have to remember warranty claims arereally for manufacturing defects only, anything else generally falls under crash replacement...
Discussion Starter · #7 ·
I thought so as well. I was thinking the worst case scenario whereby the tabs will break upon hard impact, lol..
1 - 7 of 7 Posts
