Hey Folks,
Just figured I'd share my experience with upgrading my fork with the new 2019 Debonair air piston.
I have a 2018 RS Revelation 150mm (same chassis as the Pike) which came with the old Debonair spring.
I've struggled to get fork working smooth despite relubrication, servicing, playing with tokens, yada yada yada. It really made me regret making the switch back to RS after riding Fox for the last 10 years.
While some of the limitations of this fork come from the damper, there was still a fair bit of stiction in the system to make it handle harsh over high frequency bumps. I am prone to tendonitis, so anything I can do to make my touch points smoother, I am all over.
Anyways, after hearing a few stellar reviews of the new Lyrik, I decided to install the upgrade kit. Even if it wasn't a game changer it would be a cheap experiment.
Install is straightforward if you're familiar with fork teardowns. If you're not, just have a shop do it. It seems SRAM has leveled up their customer support side of things over the last couple years, there's plenty of how-to information on their YouTube page.
The Result:
My home trails are on Vancouver's North Shore which is brutally rocky, steep and harsh on bikes. I've had the fortune of riding almost everywhere in the US and Canada and still maintain that the shore is the harshest place for a bike. This rough nature of this terrain means that if your suspension has weaknesses, they will be realized quickly.
Right off the get go, the increased negative chamber volume was noticeable. Very linear feel on the first 1/3 to 1/2 of the travel. Much more so than the previous debonair spring. The next 2/3'rds the suspension ramped up nicely, and I only bottomed out a couple times the entire ride. The mid stroke support seems to have improved. With the previous setup, I could never get the fork supple enough without blowing through all the travel on medium size hits. This no longer seems to be an issue- even with the rudimentary MoCo damper.
The stiction is gone. My hands love it.. all the chattery small bump impacts feel muted- like the suspension is doing it's work.
I only have 2 rides on it so far, but they've both been exceptionally rocky and harsh rides, and so far the upgraded Debonair is killing it.
I can safely say that this upgrade is worth it and recommended.
The Result:
