1 - 4 of 4 Posts
Normal for the TB is 120mm. The 34 will go to 140mm with a new air shaft. How much travel are you planning? The 36 is heavier and stiffer, which could be good if you're heavier. Go too long and if SC gets wind of it, it may affect warranty.
It will change performance, whether it's beneficial or a hindrance depends on how/where you intend to ride it.
1 - 4 of 4 Posts
