That does not sound correct. I weigh 185 lbs and run 180psi in my 2017 Fox DPS shock for about 30% sag in the neutral position. The Evol shocks should require more air pressure than the regular air can.
when setting up sag, did you make sure the shock lock out was off, and did you cycle the suspension several times after pumping up the shock? it is important to cycle the suspension after adding air so the negative air spring can equalize pressure.
If you did both of these things, then there might be something wrong with your shock causing extra friction, you will be able tell after your first ride.
