After reading most observations on rear end/shock, I kind of feel I’m looking for the opposite.
I like 13-14mm sag with climb switch on firm for the up. Middle is OK and when open, I’m only using about 55-60% of travel. Often use more travel on the climbs then the down. If I set sag at around 16mm I get close to what I like on the DH but everything else feel slow dead and spongy.
If I ride normal bike designed trails then 14.5-15mm sag is fine and I can blow 90% travel on the flowy stuff with G-Outs at higher speeds.
Problem is, what I like to ride is more off the beaten path stuff. Steep climbs, like grinding 28t ring, 46T rear and wishing for more bailout. Unfortunately more hike a bike, but that my problem.
Downs are often steep chunk, like soccer ball and smaller loose rock. Narrow, bushy and not that fast. Smaller ledge drops, like under 2’ and a bunch of downed logs and crap.
Shock is 2017/18 Monarch Plus RT3 (L/L) I believe its functioning properly.
Me: Fluctuate between 157-163 lbs., probably 170 kitted(?) I should actually way myself in gear.
Basically looking for something more tune-able to get more linear with top end support, it could be a switch if need be. Rather something with more external adjustability vs chasing custom work.
Wasting my time upgrading to DebonAir so I can play with air volume?
DBcoil IL and give coil a try?
Downs are 2000’ rougher/slower, possibly don’t need piggy back if that opens up options?
I have a bad habit of saving my free time for long bonk ride vs a bunch of shorter rides. It would be cool to turn some dials and knobs to get a bit of Cadillac with some support when I’m gassed. If wallowing is a compromise in those settings, then fine.
Rather not carry a pump, that's about the only way to make Monarch work for me.
