You just need the bearing sizes, you can order them individually from SKF or similar high quality bearing supplier. Beware, decent bearings aren't dirt cheap (not crazy expensive either), but there are often POS dirt cheap ones online too. 6086 bearings are quite common for mountain bikes, type that to google search and ebay to start learning about bearings.
And because i just need the bearing sizes is exactly the reason why i asked, in the first sentence, if anybody has a list of the bearings used.
How much does the "expensive" OEM kit from Specialized cost? Real World Cycling has the kit (Enduro max complement bearings) for 80 bucks
https://www.enduroforkseals.com/products/rear-suspension/suspension-pivot-bearing-kits/SBKSPE27.html
Isn't the 2017 model the same as 2016?
https://media.specialized.com/support/collateral/0000056004_R2.pdf
I'm from Europe and i can't find it. Bike24 has a lot of Specialized kits, but not for this generation of Stumpy.
The 2016 is the same as 2017, yeah, and i later found that PDF, so i'm covered. As for the kit vs. separate bearings, the kit is ~100 € as far as i can tell (in Europe), while it will cost me ~70 € with shipping (so actually 60-ish) for a full set of 16 max complement bearings for all pivots. Only the BB pivot is a full complement type in the original kit. And a full complement bearing is roughly four times the price of a standard bearing, both for the 6800 and 6801 that are needed for the stumpy. Going with standard bearings as per spec, the kit would cost 40 € plus shipping. The prices are from Kugellager express.
So for anyone looking for a quick fix, the Stumpjumper in the 2016/2017 gen requires:
-2x6802 MAX fill bearings (BB pivot)
-4x6801 bearings (2 per side on the chainstay/rear axle pivot)
-2x6800 bearings (rocker-to-front triangle pivot)
-4x6800 bearings (2 per side on the seatstay to rocker pivot)
-4x6801 bearings (2 per side on the rocker to shock yoke pivot)
EDIT: as note below, all bearings are full complement bearings in OEM spec.
