21x12x8 for those wondering
I had to get it from Trek.I believe the Trek item W541147 for this is a full complement double row bearing.
For the future, Enduro Fork Seals carries them too. That's the crappiest bit of tech on that bike. It will continue to creak periodically and seize if you don't regularly check and relube it.I had to get it from Trek. The axle bolt was seized to the bearing, no luck with penetrating oil and hammer. Had to drill the bolt out, took about 6 hours. Brutal.
Saw the new fuel's in show room had plastic cover over the bolt nowFor the future, Enduro Fork Seals carries them too. That's the crappiest bit of tech on that bike. It will continue to creak periodically and seize if you don't regularly check and relube it.
Yes any Trek dealer can get one in a few days, they updated the design of the bolt 2 from my original oneAnother issue, related to these main pivot bearings, is the bolt. My frame is new, never used, and I wanted to pull the bolts off and check the bearings for grease. Seemed to be a bit dry so I lubed the outer bearings and the bolt itself. Upon re-installing one of the bolts I noticed that it was turning hard and not going all the way in. I took it out and noticed that the threads were cross-threaded. It was not forced in just went in wrong, so now I need a new bolt on one side. Are these easy to get from Trek?
If you didn't bugger the threads too bad they may be able to be cleaned up with tap and die. The bolts are usually steel, and usually the threads that get f'd 1st is the female threads as they are usually made of aluminum (softer than steel). They also can be cleaned up. good luckAnother issue, related to these main pivot bearings, is the bolt. My frame is new, never used, and I wanted to pull the bolts off and check the bearings for grease. Seemed to be a bit dry so I lubed the outer bearings and the bolt itself. Upon re-installing one of the bolts I noticed that it was turning hard and not going all the way in. I took it out and noticed that the threads were cross-threaded. It was not forced in just went in wrong, so now I need a new bolt on one side. Are these easy to get from Trek?
