You can swap out the stock axle for something like the Wolftooth, just have to match boost/non-boost width, no extra hardware needed.
I don't think you can put an EVOL air spring in a 2017 36.
I could be wrong about that but the part numbers for the 2017 vs the 2018 onward are different and the 2018 onward (EVOL) list the air spring as NA2 where the 2017 does not carry this designation.
That would leave riding it as is, Luftkappe (DSD Runt maybe?), or Secus if you wanted to go that route or conversion to coil via Push ACS-3 or Smashpot.
In terms of cost from $ to $$$ - EVOL (if possible, doesn't look like it is), Luftkappe/DSD Runt, Secus, Smashpot, ACS-3
It can be tricky to sort out what is true because when something comes out it is presented as the greatest thing ever and afterward you see updates, changes, and complaints.
If you were cynical, always a good thing, you could argue that some of that is psychological to cultivate and drive a need/want for upgrades and the actual improvements are more subtle in many cases although at times there are actual fixes for issues or adjustments.
Then you have people who go gaga over stuff or who hate something but it is hard to work out if they are reliable as a source of information...I mean, what do they compare against, did they have a sucky setup, are they just a fan boy/girl, did they get a lemon maybe, all that jazz.
