I've got both of these forks on two different bikes: older Devinci Spartan alloy and a 2018 model Norco Range 29 carbon.
The forks feel completely different. The Spartan has the old Solo air spring and it is very supportive off the top; the Range has the latest 2019 DebonAir spring and it sets up very soft at the top of its travel. I'm 80kg but prefer the "light" tune on the rebound shim stack on the 2016 fork but haven't done any mods to the 2019 fork. The 2016 is a 170mm 650b fork vs the 29er at 160mm. Both are RCT3 models.
I've been using both these bikes for enduro racing, big mountain rides, bike park etc. The 2016 fork just saw me through a rough and raucous race this last weekend and just looked after me everywhere; the supportiveness gave me confidence to hurl myself down into the jank and have it sort me out. 5 to 8 minute descents and no arm pump at all; just a smooth controlled feeling and yet it is very economical with its travel probably only using 140 of 170mm over all the race stages (other reasons meant that I was riding without practice so I wasn't hitting things as hard as I would on more famliar tracks). My setup is fast rebound (11 clicks out) with 4 clicks of LSC.
The 2019 fork is soft off the top and I get the feeling it gives up its travel a bit easier but then the deep travel is still hard to get into. Again I go for the fast rebound and it feels to me like the stronger negative spring is helping catch the top of the rebound stroke. I have noticed on longer descents that the fork tends to try to wash out and dump me on the deck later in the descent probably when the oil has a bit of temperature build up. I'm relying more on the stability of a longer bike and I'm riding a bit more behind the front wheel.
So can I make my 2019 feel more like the 2016? Should I?
Should I just up it to 170mm spring to get a bigger (more linear) sweet spot?
Is it possible to soften the rebound spring stack (remove the Rapid Recovery preload just like I did with the 2016) and would it do anything worthwhile?
Are the dampers compatible - could I just swap my Charger 1 into the 2019 chassis?
