Gettin' back on the bike again after 10 yrs away...
Literally 3-4 mo of research to just understand where Mtn. biking has gone in the last 10 years (holy crap!) + what kind of bike I really want/need for the riding i'll be doing at 50+ anymore.
The wealth of articles on this bike here and elsewhere helped immensely, I Demo'd a '19 Transition Smuggler,...an eye opener! then finally settled on a Devinci Troy.
Looking at used bikes, I found a late 2016 Troy frame in excellent condition, cpl 3-4 small nicks on the entire frame. (Thanks Darryl!)
Targeting as many used high-end parts as possible to stretch the budget has naturally paced the build. and so I began my 1st build in over 10 years..
Specs :
- 2016 Troy Carbon Large
- Custom VentureShield frame protection
- 40mm Boost wheel set, Sun-Ringle hubs/alloy rims -
Stupid good deal, couldn't afford not to..
- 27.5x30mm F, R + 29x30mm Ft, boost/Carbon 'Mullet' wheel set
again, crazy deal on 3 carbon wheels couldn't pass on
- 29/27.5+ Pike, boost w/Debonair spring upgrade, 160mm
- Crank Bros Highline 125mm Dropper
- Origin8 35mm / 50mm stems w/Ti hrdwr
- Easton CF bars 760MM
- Carbon/Ti Seat tube clamp
- SqLab 611 saddle,
- Gore Tec Teflon coated Der. cable
- Roller bearing upper bushing upgrade to Monarch shock
- Repl. steel bolts w/Ti: Pivots, Stem, ISCG, dropper, der., shifters, etc.
- Fab'd up a custom DT protector of 1/16in. embossed marine vinyl from
top to BB.
Custom Paint (no love 4 the 'TROY' script up the SS & links, I wrapped the SS and painted/clear coated all alloy parts: Chain stays. Stems, Linkage plates, fork legs, crown w/a special clear coat that pops in sunlight.
Custom molded chainstay protector (with SUGRU moldable rubber glue!)
then wrapped in silicone fuse tape.
Hope ZS headset
Hope OG Mono 6ti & Mono M4 brakes
assessing expected ride height w/tires and when fork travel is upgraded
Still need to decide on complete drive train, 11/12sp? and which crank standard btwn Shimano, GXP, Dub,
What a learning experience so far...
1st "slack"/New Geo frame design
1st tubeless setups
1st 1x setup
1st rear gear larger than 36!
1st RS fork in 20+ years
1st RS rear shock ever
1st PF-BB ( Wtf, whose idea was this?! )
1st build over 50 lol
Mocked the bike up with everything i have so far on it and damn if i'm not jonesin' crazy hard to get it dirty!
spare a thought...
Ol' Skewl Goodness. Still Rockin after 20 yrs,....with select upgrades.. 27.5/26 Mullet FSR
