Any GXP crank should do. The truvativ stylo cranks are a good deal if buying new (250 for carbon and 125ish for aluminum). I also like the older s1400 and x9 with the removable spider. You can find those for pretty cheap these days.
FYI, there is no difference between boost and non-boost cranksets. The only difference is in the chainring offset. A boost crank is going to come with a boost offset chainring, so if your frame is not boost, that will need to be replaced. However the spindle and crank arms are identical.
