1 - 1 of 1 Posts
For sale is my 2013 Scott Scale full carbon hardtail. This is a lightweight bike with many top-tier components. Asking $1450.
Frame Material: 29" Carbon
Fork: Rockshox SID XX with hydraulic X-loc remote.
Headset: Ritchey Pro Tapered
Handlebar: TRUVATIV Noir T20 Riser Bar
Stem: TRUVATIV Stylo T40 Stem
Brakes: Sram XX
Brake Levers: Avid XX Disc
Shifter: SRAM GX
Rear Derailleur: SRAM GX 1x11
Cassette: SRAM GX 1x11
Cranks: Truativ XO Crankset - Carbon
Chainring: SRAM X-sync 32T
Rims DT Swiss XR-331, 29”
Hubs DT Swiss 350
Saddle: Bontrager
Seatpost: Ritchey Carbon WCS
Tires: Scwalbe Knobby Nic (front and rear)
The fork was serviced last fall, the bottom bracket was replace this spring and the rear tire is brand new. The only issue that I've had with this bike is that the rear dropout on the drive side has worn a bit and was causing the rear wheel to not be aligned properly. I solved this problem by switching from the original QR (9mm) axle to a DT Swiss 10 mm rear thru axle. Since this swap, I've had no issues.
The bike frame and components do have some scuffs as would be expected.
This is a great bike - I'm just selling to save money on upgrading my other bike. Pedals not included.
I would consider a partial trade (with cash) for a low end hardtail.
Located in Anderson, SC
1 - 1 of 1 Posts
