Hi Guys,
I picked up a used Scalpel with the 2013 CTD with trail adjust shock, this thing seems to have a problem with the CTD lever, trail adjust and rebound buttons:
Initially the CTD lever was very stiff, so i tried to take off the rebound (red) botton which i did with a 1.5mm allen key. Then, I tried to pull out the other 1.5mm bolt out of the main body behind the CTD lever to see if that freed things up, but I'm not sure what this bolt does.
Tried loosening and tightening this bolt, putting the rebound button back on several times, and now the trail adjust won't move, the rebound button is hard to move but the CTD lever moves a bit better.
Is there a proper way this thing goes back together? (i.e. bolt tightening sequence, if i need to do this with or without pressure in the shock, turn it upside down etc) I can't find an explosion diagram of the shock anywhere. Maybe I need to send it to Fox?
