1 - 1 of 1 Posts
Im looking to get into mtb and I can buy either of these bikes off craigslist, both are in great condition so i basically just want to know which has better components and frame. The Access is $325 and the Hardrock is $275.
Access 9.7 29er components:
FRAME: 6061 Aluminum
FORK: Rock Shox Tora SL 100mm travel
BRAKES: Avid Elixir 5 Hydraulic Disc w/ 185mm front, 160mm rear
CASSETTE: SRAM PG-950, 11/34T, 9-speed
CHAIN: KMC HG73 1/2" 11/128" 106L
BB: TruVativ Giga X Pipe XR
CRANKSET: TruVativ FireX 3.3 aluminum, 22/32/44T
F.DERAILLEUR: SRAM X.7, 34.9, top-pull
R.DERAILLEUR: SRAM X.7, long cage
SHIFTERS: SRAM X.7 Trigger
LEVERS: Avid Elixir 5 Hydraulic Disc
HEADSET: Cane Creek Semi-integrated
STEM: Forged Alloy 4-bolt, 7° rise, EXT:15"=90mm,17"=100mm,19"=110mm, 21/23"=120mm, 31.8
HANDLEBAR: MTB, butted aluminum, 710mm, 25mm rise
GRIPS/TAPE: Velo Oury
PEDALS: Wellgo WPD-801, chromoly axle
SADDLE: Velo
SEATPOST: 7075 Aluminum, 31.6, 350L
TIRES: Schwalbe Albert HS 29 x 2.1"
Rims: Mavic TN 719 Disc, 29", 32H
Hubs: CNC alloy, disc, sealed, 32H
Specialized Hardrock disc 26 in components:
FRAME
Specialized A1 Premium Aluminum 26″, fully butted, 6061 alloy, ORE downtube, externally relieved headtube, forged dropouts and reinforced disc mount, alloy replaceable der. hanger
FORK
SR Suntour SF13-XCT-MLO 26″, coil/MCU spring, 1-1/8″ steel steerer, mechanical lock out w/ preload adj., 28mm stanchions, post mount disc, 80mm travel
HEADSET
1-1/8″ threadless, loose ball
STEM
Alloy, 4 bolt clamp, 10º rise, 25.4mm
HANDLEBARS
Specialized riser bar, alloy, 620mm & 640mm wide, 8º backsweep, 4º upsweep, 25.4mm
GRIPS
Specialized Body Geometry XCT, Kraton w/ gel, 132mm
FRONT BRAKE
Tektro HDC 300, hydraulic disc, dual piston, Lightwave style rotor, 160mm
REAR BRAKE
BRAKE LEVERS
Tektro, hydraulic lever
FRONT DERAILLEUR
Shimano Altus, 8-speed, 34.9mm clamp, low mount, top-swing, dual-pull
REAR DERAILLEUR
Shimano Acera, 9-speed, SGS Cage
SHIFT LEVERS
Shimano Altus, 8-speed Rapidfire plus, SL type w/ optical display
CASSETTE
Sunrace, 8-speed cassette, 11-34
CHAIN
KMC X-8, 8-speed w/ reusable Missing Link
CRANKSET
SR Suntour XCT, 8-speed, square taper spindle
CHAINRINGS
42/32/22, steel
BOTTOM BRACKET
Square taper, cartridge bearing, 68mm shell
PEDALS
Composite platform, w/ reflectors, 9/16″
RIMS
HR Disc, 26″, alloy double-wall, disc, pin joint, 25mm, 32h
FRONT HUB
Alloy disc hub, double sealed loose bearing, steel axle, QR, 32h
REAR HUB
Alloy disc hub, double sealed loose bearing, steel axle, steel cassette body, QR, 32h
SPOKES
Stainless, 2.0mm (14g)
FRONT TIRE
Specialized Fast Trak Sport, 26″x2.0″, wire bead, 40TPI
REAR TIRE
INNER TUBES
Schrader valve
SADDLE
Specialized Body Geometry Hardrock, steel rails, 143mm width
SEATPOST
Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm, 300mm or 350mm
SEAT BINDER
34.9mm, alloy QR, nylon washer
1 - 1 of 1 Posts
