1 - 2 of 2 Posts
Does anyone know if there is compatibility between the 2011 SJ-FSR Carbon frames and the 2012 updated rear triangle (with the 142/12 thru axle)?
Spec is tooting about the new rear end being stiffer, and that's an area that could be improved on my 2011.
Beyond compatibility, there will then be the issue of availability... Not sure how easy it would be to get the pieces even if they're made as a perfectly compatible fit.
1 - 2 of 2 Posts
