Just joined the other day and have read countless reviews of both bikes, but wanted a few more opinions. I guess I'm having the most trouble with which components are better between these two bikes. The prices are very close. If anyone wants to throw in their two cents I would be very appreciative.
My background:
First mountain bike, will ride some around the neighborhood and park trails, nothing too crazy. Seems like size 19 frame fits me the best that will be a constant with either bike. The Mamba felt slightly better, but I liked the Rockhopper also. Didn't notice a huge difference and that's probably because I have no frame of reference. Simply looking for the highest quality at the best price between the two.
Here are the specs and prices:
2012 Trek GF Mamba - $863.99 + tax
Shifters -Shimano Alivio M430, 9 speed
Front derailleur - Shimano Acera
Rear derailleur - Shimano Deore M591
Crank - Shimano Alivio M4308, 44/32/22
Cassette - Shimano HG20-9 11-34, 9 speed
Pedals - Wellgo ATB, boron axle, steel cage
Fork - RockShox XC32 w/coil spring, TurnKey lockout, custom G2 Geometry, 51mm offset crown, 100mm travel
Brake - Shimano M446 hydraulic disc brakes
2011 Specialized Rockhopper Comp $876.95 + tax
FRONT BRAKE - Shimano BR-M505 hydraulic disc brake, dual piston, 160mm rotor
REAR BRAKE - Shimano BR-M505 hydraulic disc brake, dual piston, 160mm rotor
BRAKE LEVERS - Shimano BR-M505 hydraulic
FRONT DERAILLEUR - Shimano Alivo, 34.9mm clamp, top swing, dual pull
REAR DERAILLEUR - Shimano Deore 9sp Shadow Long cage
SHIFT LEVERS - Shimano SL-M590 Deore trigger
CASSETTE - Shimano HG30, 9-speed, 11-34t
CRANKSET - Shimano FC-M430-8, Octalink spline
FORK - RockShox Tora TK 29 SL, magnesium lower, 32mm Cr-Mo stanchions, 1 1/8" alloy steerer, coil spring w/ preload adj., turn key damping w/ LO & external reb. adj.
My background:
