Hey - bought myself a band new closeout Rock Shox SID RLT 29" 120mm. It was clearly noted as Solo Air on the box and there is also a Solo Air sticker on the back of the fork lowers. Interestingly, the date on the box is August 2012. This threw me a bit because I thought Solo air was released in 2013. Anyway, I took it apart to reduce the travel down to 100mm and noticed that there is an air valve located in the bottom of the air shaft - see photo!
In the rock shox part list under SIDB 80-120mm:
http://cdn.sram.com/cdn/farfuture/_.../files/techdocs/2014_rockshox_spc_rev_a_0.pdf
...two air shafts are shown, position 32 which is dual air assembly and 33 which is solo air assembly. The dual air version clearly has a negative valve (40) whereas the solo air version doesn't. THat said my air shaft looks like 33 and not 32. Note that my air shaft is mounted to the fork lowers with a bolt and not a dual air nut, so you can't access the internal valve without removing the bolt.
I am stumped - can anyone help me here - do I have a dual air or solo air fork?
Thanks Anthony
Thanks Anthony
