My joke at the shop is that platforms are the training wheels of pedals.Flynnster said:Looks amazing!! Surprised on the pedals though, woulda expected platforms.
The 5 Spot is a customers bike. The DHR is my personal race rig. I'm planning on a 2011 5 Spot as my trail bike and Super D racer, but it won't be as nice as the one we've posted.rippling over canyons said:Beautiful bike along with the 5 Spot you also posted. Why not 203mm rotors?
The 2011 DHR has a 63 degree head angle. That is World Cup slack. Meaning you have to be racing very steep courses or at least be very very fast. I'm not that fast (not really even close anymore) and I'm OK with that. The past two seasons I'ver raced a bike that was set at 64.5 and I never felt it was too steep. A steeper HA works better for most riders on flat corners which we have a lot more of than last seasons WC series.RPG said:Noticed you went steeper on the HA. Can you elaborate on your rationale? I have noticed the DHR to be fairly slack (in pictures, i've never rode one). It is interesting to see you go the other way. Real nice build too!
I was initially turned off by the DHR because of the slack HA. I live in the northeast and have no reason for a bike that slack either. You just peaked my interest in the DHR again. I've owned 2 DHR's in the past (the old 7" design and the square tube with the romic). I may have to get back in the Turner game once again. Thanks for sharing your insight.[email protected] said:The 2011 DHR has a 63 degree head angle. That is World Cup slack. Meaning you have to be racing very steep courses or at least be very very fast. I'm not that fast (not really even close anymore) and I'm OK with that. The past two seasons I'ver raced a bike that was set at 64.5 and I never felt it was too steep. A steeper HA works better for most riders on flat corners which we have a lot more of than last seasons WC series.
The Cane Creek AngleSet comes with 3 options. It has a .5 degree, 1.0 degree, and 1.5 degree offset cup. They can be installed to slacken or steepen a HA for a total change of 3 degrees. It seems they are based on about a 5" head tube. So, if your head tube is smaller than 5" you will get more of a change than is specified on each angled cup. If it is bigger than 5" you will get less of a change. I wanted 64 degrees and due to the 4" head tube on the medium DHR I used the .5 degree cup to get about a .8/.9 degree steeper HT. It also raised the bottom bracket a bit to about 13.625, which is still very low.
I know what you're saying. I'm pretty pissed too that ENVE doesn't have carbon bar plugs for the DH bars....I MEAN REALLY.kidwoo said:Oh my god, those cheap bar end caps. I can't believe you took that bike out in public looking like that. And those cranks......jeesh......there are at least 3 newer model options out there.
Looking good Scott!You should try riding the stock head angle if you haven't already. You and I are about the same size and I have zero problems getting all over the front end, even on flat northstar trails. Shorter cockpit with the same old (08) wheelbase does that for ya.
Now go pound on that thing!!
I've been a long time fan of the DHR. Even owned one for the last two years, but it was mostly raced by one of our sponsored Pros. I used it a lot for testing shock tunes.RPG said:I was initially turned off by the DHR because of the slack HA. I live in the northeast and have no reason for a bike that slack either. You just peaked my interest in the DHR again. I've owned 2 DHR's in the past (the old 7" design and the square tube with the romic). I may have to get back in the Turner game once again. Thanks for sharing your insight.
On both the front and rear I'm using Shimano Post Mount 180mm adapters. They come with those CPS washers because the bolts, caliper and adapter don't line up in a perfect line.Relayden said:Nice ride...wow impressed with the weight.
What front brake adapter you have there?
We have a special carbon cutting hacksaw blade, but I've also had good results from a standard 18T per inch blade. I then did a light sanding with fine sand paper, and put some CA (super glue) on the exposed ends.san_andreas said:@[email protected]: Really nice ride !
How did you cut those ENVE bars ? Did you seal the ends of the bar after cutting ?
