2011 Specialized Safire Comp full-suspension bike size small for sale. This is designed for women and is an excellent ride. I haven't ridden it much since I had my kid, and likely won't for awhile. So I thought I'd pass it along to someone who can enjoy it. Asking $800. Available for pick-up in Winters, California. Can be shipped, but buyer will pay for shipping and packaging.
Pictures and details below.
FRAMESET
FRAME
M5 manipulated alloy frame w/ women's XC Trail geometry, ORE TT/DT, tapered HT, DMD front derailleur, sealed cartridge bearing pivots, replaceable derailleur hanger, disc only, 120mm travel
HEADSET
1-1/8 and 1.5"" Threadless, Campy style upper with 1.5"" lower, cartridge bearings
SEAT BINDER
34.9mm clamp ID, 7050 hard annodized alloy collar w/ QR, black
SUSPENSION
REAR SHOCK
Custom Fox Triad II for Specialized, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, rebound adj., 6.5x1.5"" extension
FORK
RockShox Reba RLT, tapered alloy steerer, compression and rebound adj. LO w/external floodgate adj., standard drop-outs, 120mm travel
WHEELS
RIMS
Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
FRONT HUB
Specialized Hi Lo disc, laser-etched logo, OS 24 end caps, sealed cartridge bearing, RWS, 28h
REAR HUB
Specialized Hi Lo disc, laser-etched logo, double sealed cartridge bearing, QR, 32h
SPOKES
DT Swiss Champion 1.8mm (15g) stainless
FRONT TIRE
ESKAR2 Control 26x2.3
REAR TIRE
Specialized ""The Captain"" Control, 60 TPI, 2Bliss ready aramid bead, dual compound, 26x2.0""
INNER TUBES
Presta valve
DRIVETRAIN
FRONT DERAILLEUR
SRAM X.7, S1 direct mount for DMD, bottom pull
REAR DERAILLEUR
SRAM X.9, 10-speed, long cage
SHIFT LEVERS
SRAM X.7, 10-speed, aluminum trigger
CASSETTE
Shimano HG81, 10-speed, 11-36t
CHAIN
KMC X10, 10-speed, nickel plates
CRANKSET
Custom SRAM S-1250, 7050 alloy arms, 10-speed triple, GXP spindle, S/M: 170mm, L: 175mm
CHAINRINGS
44A x 33A x 22A, 4-bolt, 104/64mm
BOTTOM BRACKET
SRAM GXP, outboard bearing
COCKPIT
STEM
Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
HANDLEBARS
Specialized XC low-rise bar, 2014 butted alloy, S/M: 640mm wide, L: 660mm wide, 8 degree back sweep, 6 degree up, 31.8mm
GRIPS
Specialized XC lock-on
SADDLE
WTB (replaced from original)
SEATPOST
Giant (replaced from original because it was too short)
BRAKES
FRONT BRAKE
Custom Avid Elixir R SL, hydraulic disc, alloy backed semi-metallic pads, reach adjust, stainless hardware, G3 Clean Sweep rotor, 160mm
REAR BRAKE
Custom Avid Elixir R SL, hydralic disk, alloy backed semi-metallic pads, reach adjust, stainless hardware, G3 Clean Sweep rotor, S/M: 140mm, L: 160mm rotor
BRAKE LEVERS
Custom Avid Elixir R SL hydraulic, tool-less reach adj.
ACCESSORIES
PEDALS
Shimano clip-in
Pi
