Bought a well used Flatline pro with a bit of what I initially thought was bearing play. Turns out although the bearings will be replaced, there is some significant IGUS bushing wear (worn through) in addition to the hex pin being worn down.
Anyway I have all the parts & everything is torn down but the original Igus bushings feel like they're glued in. Anyone know if they are from the factory? If so what glue was used? My thoughts are a bit of heat to see if I can get the glue flowing rather than tearing them out and potentially making a mess of things.
If you've got any suggestions I'm open to them.
Thanks in advance.
Thanks in advance.
