Just scoped this on Sicklines
Kona has been busy creating a new downhill bike. Their previous offerings like the Stab clearly had some influence over this new design. It's nice to see Kona trying new things for 2011.
* 83mm bb shell
* ISCG-05 tabs
* 150mm rear end - includes an alloy axle
* 9.5 x 3″ shock
* 200mm of travel
" This bike represents a whole new platform for us, and there are a lot of neat little details to discuss. The bike is a 4-bar. Tried and true, refined, rather than a "regurgitation with facelift" like many of the "new" designs currently hitting the market."
"The main pivot and rocker pivot use the same bearing, an 6903-2RS1 with 17mm inner diameter, 40mm outer diameter and a width of 12mm. The chain stay to seat stay and seat stay to rocker pivots use 66200-2RS1 which has a 10mm inner diameter, 30mm outer and 9mm width. You'll notice that the pivot bolts for chain stay and rocker pivots are in double shear."
1.5 Zero Stack tapered headtube- "The 1-1/8 upper and 1.5 lower bearings are both angular contact bearings. Should it ever come time to replace them it is as simple as removing the fork and catching the bearing as falls from the frame."
* 83mm bb shell
* ISCG-05 tabs
* 9.5 x 3″ shock
* 200mm of travel
