1 - 18 of 18 Posts
May The Force Be With You
What spring rate for a 200lb'er, 350 or 400?.. currently on 300x2.75 and way too soft
Discussion Starter · #4 ·
cool beans. thank you!
Discussion Starter · #7 ·
will the DVO Jade with 241x76 (9.5 x 3) fit ?
Discussion Starter · #9 ·
great
Discussion Starter · #10 ·
i might be looking at getting a Medium frame, would have change make any difference depending on the year?
Most recent jedis (after 2014) are longer by 10mm if I recall. (and they use a 240mm shock) between 2011 and 2013 there is not much difference, most visible one being the machined links.
Discussion Starter · #12 ·
I'm looking at a 2018
2018 has more traval, 27" wheels, slacker head angle, more "linear" suspension, a tad lighter. I don't know what are the difference between 2014 and 2018.
So it's more modern, but you'll be at home as it still work like a jedi, a bit better.
Discussion Starter · #14 ·
I just have to do some geometry comparisons to see what I can swap over
Discussion Starter · #18 ·
either way.. that's what i'm looking at. my small 2011 is one size too small
1 - 18 of 18 Posts
