1 - 6 of 6 Posts
Currently running the stock RP23- will the fox van shock work or foul/not fit? Of course I'd run the reservoir facing downwards :thumbsup:
I had an 06 4x and asked SC about running a coil, they said it would make it feel like it has less travel. It was designed around air, but I'm sure Push could valve a coil over in a way to make it feel however you want. I would stick with air unless you are having durability issues. From what I was told it won't make it feel any better really, just more progressive at the end of the stroke; if you are DJ'n with it you may prefer the shorter travel feel?
Discussion Starter · #4 ·
Thats the thing. I used to have a Blur4x with a 5th air air can. It felt great (simple as well) however this rp23 feels sometimes jerky sometimes squats etc. The frame is new old stock.
1 - 6 of 6 Posts
