1 - 2 of 2 Posts
Discussion Starter #1
I'm trying to replace the dust wipers on my Talas fork and was unable to find actual instructions on the fox site (WebHelp), I can't even find good instructions on how to remove the fit dampener. Normally you loosen the top cap and then screw the bottom nut on enough to hammer it out. Unfortunately the bottom nut isn't even close to big enough to do that, the little prong sticks out well past flush before the nut is threaded on at all. I'm afraid of just trying to pull the dampener out that I might damage it.
How do I remove the FIT dampener?
http://imgur.com/erjYe
http://imgur.com/UtLo7
Should I just screw the bottom nut on, put a socket over it and then hammer it out?
1 - 2 of 2 Posts
