2010 SRAM X7 shifter drops internal cable on up-shifts
Hi all,
I have a brand new 2010 Giant Reign that I'm customizing for my riding.
While on the bike stand, the rear drive-train exhibited a strange behavior. At the lowest gear--largest cog in back--one click of shifting will cause the chain to skip a cog and effectively shift two speeds instead of one. Afterwards, the rear shifting is completely unpredictable, until I shift to the highest gear--smallest cog in back.
So I opened the rubber window of the X7 shifter housing that is used for replacing the cable and that's where I saw that the shifter cable is slipping or dropping off the carrier wheel inside. This only occurs from the largest cog, when cable tension is at its highest. Shifting to the smallest cog decreases cable tension significantly, repositioning it back onto the carrier wheel to work normally again.
Has anybody else experienced this annoying behavior with the 2010 SRAM X7 shifter? Did you devise a fix for this? I have an older 2006 SRAM Rocket shifter that works just fine.
EDIT: Sorry, I mistakenly labeled the shifter "X9", when it should be "X7" for that model Reign.
Hi all,
