if you are sure it's the housings, you can zip-tie them together so they don't bounce off one another
I hadn't thought of the housings hitting each other. Interesting possibility. I thought it was the housings hitting the frame (which is very thick, but with thin walls, like a drum).Lambdamaster said:if you are sure it's the housings, you can zip-tie them together so they don't bounce off one another
