1 - 5 of 5 Posts
Any changes to the Flux or Spot for 2010?
Or are they wrapped up with release of the DHR and RFX for 2010
Your Best Friend
My bet is we'll see a revised Hex link interface on all DW models next year.
Wicketed
weren't the flux chainstays going to be revised to they could take XX?
After seeing the Sultan with a drilled rear mech cable route through the upright, I believe either that will be used on all models (it shouldn't be size dependant).
Alternatively, there must be scope to route straight through the chain stay tubing. It would be close to the front mech at rest, but would only ever move away from it under compression. If you ran a double and bash guard it would clear it easily.
Wheel Bicycle tire Bicycle wheel rim Spoke Bicycle part
Who is going to be first with the drill, and dremel off the three zip tie fixtures? :eekster:
1 - 5 of 5 Posts
