1 - 2 of 2 Posts
So Specialized gets rightly criticized for using shock dimensions that aren't readily available...for my 2009 Stumpjumer Comp that is a 7.25 X 1.75. But it looks like for 2014 there is:
FOX CTD BV Trail Adjust 7.25 X 1.75
Monarch RT3 - 7.25 X 1.75
I found just a couple of forum posts where the RT3 as used as an upgrade...anything with right dimensions should fit?
As long as the eye to eye and stroke length are the same they will fit. The only other thing you would want to check is the compression and rebound tunes of the new shocks are suitable for your bike. The wrong one can mess up how the suspension will work.
1 - 2 of 2 Posts
