1 - 18 of 18 Posts
Just finished building it, hope you like it. The frame size is XL, does the weight seem high for the way it's setup? I hoped it would be under 20 lbs, similar in weight to eliflap's Scalpel, when he still had the mavic wheels. He does have a medium frame size, but im not sure wat the weight difference between M and XL is.
The list of specs is under a similar post in the weight weenie section.
FIRENZE rulez !!
the differences with my scalpel are:
cassette ( seems and XTR 225 gr , mine is a Recon alu 150 gr )
stem : seems one piece 120 +20° 270 gr , mine is tube+stem 260 gr
bar : FSA carbon about 130 gr , mine is Schomlke 66 gr
rear shoch : FOX about 260 gr with hardware , mine is DT Carbon 168 gr with hardware
tyres : Continental ( latex ? inner tubes ? ) about 500 + 500 gr + 200 gr tubes , mine are Maxxis 310 gr +310 gr+ 60gr latex
rings: 44-29 Cannondale are 120 gr , mine are 52 gr
rear derailleur : stock X.0 199 gr , mine with carbon inneer cage + pulleys 165 gr
rotors : stock Avid 192 gr , mine are scrubs 108 gr
brakes : Ultimate 240 + 250 gr , mine are Marta SL 212+ 234 gr
all titanium screws on mine - 40 gr
you forgot that he has paint on his frame ;)
Discussion Starter · #5 ·
eliflap i was referring to the set up you have on the first page of your thread http://forums.mtbr.com/showthread.php?p=4183841. Im just looking at the pic where it weighs 8.76 kg and you definitely have still had the FSA bars, one piece stem, stock chainrings, and no tubes rotors. So without chaining my wheelset wat you reccomend changing to get it under 9 kg. Is it harder with mine cause of frame size, but isnt the new lefty lighter?
FIRENZE rulez !!
for lefty 2009: cannondale write 1155 gr
only you can remove it from your bike and weight it ... at the moment it's the first i saw ...
my lefty was 1242 gr when arrived to me
your tyres are ... ? sealed with latex or with inner tubes or ust version ?
FIRENZE rulez !!
weight loosing is however to be compared to use of bike ... and money
race or normal trail without anyone at your back ?
i ride in the second way , escaping from nobody :thumbsup:
so i can mount a light cassette , a light chain saving 100 gr both ( recon and kmc )
a light rotors saving another 100 gr ( scrub's , stans if available , carbon ti )
a light carbon saddle saving another 80-100 gr ( ax lightness , tune ...and so on )
LA CHÈVRE
A few heavy parts: FSA bar is claimed around 130 but usually weighs much more, Mavic wheels are always quite heavier than claimed, Avid brakes are heavier than the Maguras... but, 9.5kg is pretty good IMO, especially with such a large frame. Mine (08 medium) with the SLR wheels and heavier UST tires, same bars, 08 Lefty SL weighs 9.6kg...
Discussion Starter · #12 ·
i weighed my bike again today and the air is much colder and dryer, it weighed 9.47 kg. il get a pic up soon, funny how condensation weighs .04 kg.:) :) I also ordered token collar which will subtract some more.
@eliflap: you mean:
stem : seems one piece 120 +20° 270 gr , mine is tube+stem under 200gr
my 08 Scalpel Team (stock) + KCNC seatpost, foam grips, CF bottle cage and still @ 22.40 lbs :madman:
I must have the heaviest Scalpel team :confused:
1 - 18 of 18 Posts
