1 - 14 of 14 Posts
NMBP
Does anyone know if it is possible to convert the 2009 100mm Reba Race to 120mm? Or is the 120 a separate beast? I know the 80mm and 100mm can be converted using a spacer. I am getting conflicting info here. (The new Fox 120mm chassis is basically different from the 80 and 100 versions.)
Thanks, and Happy New Year! :thumbsup:
Yes, you can quite easily convert it to 120mm by removing the spacer. I had to remove the lowers to do mine...I tried the old method of pushing the stack up through the top of the fork & most of the stack stayed in the leg :D
Just follow the instructions you can download off their web site & you should be fine.
I bought an 80mm reba for my wife & removed both spacers for 120mm of travel. The fork was never ridden prior to changing the travel so no comparison can be made. Be sure to examine your post mounts prior to installing the fork. Make sure you can thread the bolts in easily...otherwise you will have to remove the paint overspray with stripper or by tapping the threads.
Too much misinformation
I was looking into the same thing for my wife's new bike and had trouble getting a straight answer on this. Why is it that on SRAM's website they say that the Reba Race and SL can only run at 80mm or 100mm? It will be great if we could indeed convert one of those to run at 120mm. Anyone know if the same goes for the SL?
Premium Member
nope not necessarily... but it sure is fun to play with :)... also gives you a little tunability in your geometry :)
i've got a g2 fork on my KM... at 80mm it was a tad quick... @ 100mm it's perfect... tad more upright... basicly it handles like the stock KM did... but with a little taller BB (good for me)
on the other hand a friend of mine rides a RITA... 100mm stock... he's running and loving a fox g2 fork @ 80mm...
different strokes
The 80/100mm forks might not have enough extra stanchion to have full bushing support when extended to 120mm. I don't know for sure, but that is certainly a strong possibility that they would minimize weight on the more XC 80/100 forks by cutting them shorter than the 120mm version. Even if that is the case, it should still technically work
I was looking up a spare part from their Spare Parts Catalog, and on the REBA page (pg 38) note #9 on the bottom says "Reba 29er with standard quick release (not Maxle Lite): maximum travel setting = 100mm. Reba 29er Maxle Lite: maximum travel setting = 120mm."
May be the CYA lawyer-ese, but it's something and one heck of an odd place to post it.
1 - 14 of 14 Posts
