Has anyone else had an issue trying to use the Hope matchmaker with Saint shifters on the Tech M4 levers? For some reason, with the shifter attached to the matchmaker, you can't even bolt it to the lever???? :madman:
Hope offers a Shimano version they claim is compatible with XT/ Saint.Xave said:I thought the matchmakers only worked with Sram
Yes, exactly as you described. I am charging the camera & will post a pic in a bit.SteveUK said:Do you have a picture of the failure? Is the 3-bolt mount on the underside with the shifter body under that?
HOPE do have the clamp for SRAM shifter...fcojavier said:¿Do they work ok with SRAM shifers?
I miss the Juicy´s matchmakers after switching from Avid Juicy to Hope M4.
TIA
Nope, its not compatible with XTR shifterCJLED said:Any idea if these will work with the XTR 970 shifters?
ouch, really? So you can't run Hope M4s with current XTR shifters!? That would take the Hopes off my list for my next build...kianlee said:Nope, its not compatible with XTR shifter
He was referring to the matchmakers. You can run the xtr shifter separately on the bar.JChasse said:ouch, really? So you can't run Hope M4s with current XTR shifters!? That would take the Hopes off my list for my next build...
