Thank you...thank you very much...(said in my best Elvis voice)
Here you go:
Sonix/Xeon Bolt Torque Ratings
Upper Links (Sonix)
• Lower Pivot: 130-140 lb-ft
• Connecting Brace: 130-140 lb-ft
• Upper Link Bolt / Shock Mount: 120-130 lb-ft
Upper Links (Xeon)
• Upper Link Bolt / Shock Mount: 150-160 lb-ft
Bottom Bracket Pivots (Sonix & Xeon)
• Main Pivot (13mm hex socket): 110-120 lb-ft
• Main Pivot (5mm allen): 120-130 lb-ft
• Main Link Bolt: 130-140 lb-ft
Shock Mount (down tube – Sonix & Xeon)
• If 5mm allen key: 110-115 lb-ft
• If 4mm allen key: 90-100 lb-ft
Here you go:
Upper Links (Sonix)
Upper Links (Xeon)
