Will the real Pro-Pedal Position please stand Up.
With the Shock Facing Foward...i.e. with the Pro Pedal Lever facing toward the Front of the Bike, Which way do you set the Pro Pedal Lever (Left or Right) to enable the Pro Pedal feature.
Reason I ask, is the User Manual for the 09 Fox RP23 shows setting the Pro Pedal Lever to the Left to enable Pro Pedal..BUT...The drawing in the Manual has the Schrader Valve facing toward the Right. This does NOT make sense. The Schrader Valve for the 09 Model is on the Left when the Shock is facing Toward the front of the bike.
So, which way to enable Pro Pedal...."Left" or "Right"?
See picture compared to User Manual drawing:
