1 - 13 of 13 Posts
Quick question. Ive been offered a great deal on a Fox36 float fork. Is there anyway you can change the fork height by adjusting the air pressures? (like Pike air)- i.e. add more neg in and it sucks the fork down into its travel?
Reason being is at 160 the fork would be 5-10mm too long for all day riding on my frame. I dont want to go with a 150 32 due to the QR15 (slight flex) and I havent been offered a great deal on a set of Revs!
noMAD man
hora said:
Is it easy? How do you do this/using standard spacers? Very interested as Van R's opens up the search to lower prices for me.
The method of spacer stacking that Fox uses is on their site. Most all Vanillas and Floats allow this. It requires a simple "leg drop" disassembly, not a full damper teardown.
I converted my RC2 Talas to coil with reduced 150mm travel. On my bike (Blur LT2) I found that the 160mm setting was too slack and 130mm too steep. Reducing to 150mm balances the bike beautifully and I don't miss the travel adjust - plus I've rediscovered how plush a coil can be!
Was a simple case of removing the air cartridge and talas assembly in the left leg and replacing with the vanilla coil assembly and the correct spacers.
How did you lower your fork? I thought the only way to lower the VAN 36 was to make the coil shorter. Did this change?
Bike shop did it for me - they have done several conversions. My understanding is that they used spacers as per this diagram I have borrowed from the pinkbike forums. Not sure whether they had to cut the spring or not - I would presume that it would need to be, otherwise the spring would be compressed and initial preload would be too high.
How much does the conversion cost?
Cost me about $350NZ - which is about $230US - however I was converting a 2009 RC2 Talas, so had to buy a whole new set of vanilla internals for the spring side leg to replace the talas and air cartridge assemblies. Most of the cost was these parts. Also - to put the cost into perspective, a new RC2 Talas in NZ is about NZ$2400 (US$1650) - bike parts are expensive here.
Would be lots cheaper if I had been converting a vanilla, in which case it would have only been the spacers and a small amount of time.
1 - 13 of 13 Posts
