The Problem:
Der. can not swing in far enough, even with limit screw all the way out and all cable tension removed...so the chain is ever so slightly rubbing the inside cage when I'm in granny gear - which I'm in alot
I am running the following 3x9 set-up:
Chris King BB (with one spacer on drive side)
Race Face Dues XC crank 22x32x44t
SRAM PG980 cassette 11-34t
Stock LX DMD Fr Der.
In addition the chain has issues dropping from middle to granny unless I'm within three gears of the 34t cog...thoughts?
